Configurable voltage ramp generator with myRio
After looking some documents, I found that there is a function similar to DAQ Assistant.
Required and Optional Software to Program NI myRIO
See second image and try it.
Certified LabVIEW Developer
GCentral
Message 11 of 22
(1,243 Views)
I just checked them and they present the same problem, which is that the function's input can't be a waveform, but I need to output the waveform (the voltage ramp) which has been coded in the images that I posted above.
Message 12 of 22
(1,233 Views)
Well...... myRIO isn't function generator, you should develop your own code to generate waveform on myRIO.
If myRIO has a function which only generate 1 point signal, you can use it.
For example, put it into while loop, prepare ramp data as array, write the data continuously.
GCentral
Message 13 of 22
(1,223 Views)
I used the high throughput FPGA add on to get n samples (I guess it is better for waveforms) and made the waveform into a 2D array then the array was the input for the myRio write function.
The code ran but it gave me an error can you help me with it?
The 2 images attached show the code and the error
Message 14 of 22
(1,209 Views)
Hi Habch,
Why don't you read the myRIO help and related documents?
(Did you create that myRIO task with just one channel, but then you provide two channels with your 2D array?)
Where did you use that FPGA function?
Why do you create a waveform just to convert it into a 2D array? What's the point of using waveforms then???
Message 15 of 22
(1,202 Views)
Error Codes (myRIO Toolkit and roboRIO Toolkit)
We can search the error information on web.
I guess dimension of 2D array should be 1*N or N*1 because configured channel was only one.
GCentral
Message 16 of 22
(1,209 Views)
It was made into a waveform to give a linear ramp voltage generation, but myrio funtions can't recieve a waveform input (unlike cdaq) so i transformed it into a 2D array with the time and Y being the 2 columns so i could input it in the write function of the myRio.
Message 17 of 22
(1,205 Views)
It says "The number of scaling constant values provided does not match the number of channels that you specified."
But if i give a 1*N array then how will i control the time of the ramp,
With the sample rate frequency?
Message 18 of 22
(1,198 Views)
Hi Habch,
You might read the myRIO help - as I did. There is the possibility to output "n samples"
Message 19 of 22
(1,187 Views)
So this says that the output time between 1 sample and another (so the 2 successive numbers in an array) is that decided by the sample frequency which can be between 1 and 80 khz for the write function.
Is that correct?
Message 20 of 22
(1,180 Views)
