Configurable voltage ramp generator with myRio
Hi Habch,
it says so. (1 kHz to 80 kHz)
Message 21 of 22
(347 Views)
Hey guys thanks a lot to the both of you, in general the code is running and I finally understand each step and function.
I will test it when I can use the rest of the equipment in the following days, I will get back to you with the result if you are interested, but either way thanks a lot and KUDOS
Message 22 of 22
(339 Views)
