Connect Non-TTL rotary encoder to USB-6356 (preferably counter)
I have a rotary encoder with complementary outputs (datasheet). Its maximum output frequency is 125kHz.
Because I don't understand how to appropriately use and size pull-up/down resistors, I'm unable to get this to interface nicely with LabVIEW code and DAQmx. (The crucial point being, I suppose, that the input voltage is 12..24V (I have 17V since the power supply is also controlling some load cells/amplifiers requiring 14..24V) and the output seems to be around 12V high and ~350mV low with no external resistors pulling in any direction).
Ideally, I would like to (using as few additional hardware components as possible for a good solution) connect my encoder output to my NI USB-6356 DAQ board and then have it count edges using DAQmx.
Currently, I have to use an AI Voltage channel, after connecting PFI8 (the Counter0 terminal) and the AnalogComparisonEvent, then a separate CI Cnt Edges read. This isn't too terrible, but it's quite a bit more to set up (boo-hoo) and more importantly, requires the use of an AI. The speeds make it more challenging for me to get reliable results (perhaps because my code is bad) when using a comparitively slow AI, instead of the very fast digital counter inputs.
What should I be doing here?
GCentral
(4,507 Views)
Hi cbutcher,
You really should. It's just basic electrics with Ohm's law and Kirchhoff rules!
Which encoder do you use? Your datasheet lists several options…
3 resistors (pull-up, pull-down, input) and a Z-diode (5.1V) to protect the DI pin…
According to the datasheet of the USB6356 you could even connect your encoder directly to the DIO pins, but I would prefer some external protection circuit to be an the safe side! (It already mentions an internal pul-down resistor you just need an input resistance with a Z diode…)
(4,468 Views)
The CWZ5GH - a small functional circuit diagram is given on the first page. It consists of a pair of transistors (one PNP, one NPN, each being connected to the appropriate power line (+ve, gnd) by a 7.5 Ohm resistor, with that in series with a 24 Ohm resistor to output.) Simulation with LTSpice and reading on wikipedia give me a basic understanding of pull-up/down but it's unclear how I would size a pull-down to get a 5V high for arbitrary input voltage. I could size it for 17V, but then if I change to 16V for some reason, my resistor would need changing (Perhaps this is just how it is, without a comparator circuit?). Seemingly a pull-up resistor will make my high level be the same as the power +ve rail, which will be far too high to be recognised as a 5V TTL for LabVIEW.
Your description of components needed makes me think I should have the output connected to both +ve and gnd with a resistor each, then connected using the diode to prevent voltages greater than 5.1V being passed as a digital input - I suppose that this neatly avoids having to size the pull-up resistor too carefully to the power supply, but I imagine you didn't mean for me to use it as a voltage regulator.
GCentral
(4,462 Views)
Accepted by cbutcher
Hi cbutcher,
the encoder uses a push-pull output which simplifies the design. The internal pull-down of the USB6356 makes it even easier:
(4,458 Views)
Thanks. Was trying to preview the last post, then thought some more - seemingly accidentally posted it, and then was editing when email let me know you posted again.
Will think more before posting lots, but at least I understand your answer now.
Thank you again
GCentral
(4,456 Views)
