Connecting a Chemyx fusion 4000X Syringe pump to labview
 I currently got a Fusion 4000x Syringe pump and I have been trying to connect it to LabVIEW using the drivers provided by the company. All the examples from the company gives me an error. does anyone have a modified example that I can use with my pump? Also, every time I try to scan devices it doesn't show any devices connected.  I'm kind of new using LabVIEW. my pump is connected to my pc through a usb-b to usb cable. I have attached the manual of the pump.
Fusion4000-X-Manual.pdf (chemyx.com)
Message 1 of 23
(2,850 Views)
I installed the drivers and didn't received any errors.
Make sure you have installed the  VIPM (VI Package Manager) VIPM - Download
You need to install the drivers from this page
LabVIEW™ Driver for Chemyx Smart Syringe Pumps
Message 2 of 23
(2,835 Views)
Just did. Now I get a notification saying that the syringe pump can’t be detected.
Message 3 of 23
(2,825 Views)
Did you select the correct port before running the program?
-AK2DM
Message 4 of 23
(2,820 Views)
Yes, I selected the right port. When i hit run should I click on something on the syringe pump? to make the pump run by the computer? also, there's no more errors in drivers' examples. only thing is that nothing happens when I hit run on LabVIEW.
Message 5 of 23
(2,773 Views)
Also, this is what it shows every time i try the examples.
Message 6 of 23
(2,769 Views)
Check the device manager : it will show what ports are detected in your computer.
Message 7 of 23
(2,764 Views)
com12 Is the syringe pump
Message 8 of 23
(2,760 Views)
Did you check the system settings of the pump ? (page 27). Are you using DB 9 or USB on the syringe  ?
Message 9 of 23
(2,756 Views)
ive been trying with this code. but it shows me this error too.
Message 10 of 23
(2,755 Views)
