Connecting a Chemyx fusion 4000X Syringe pump to labview
im using usb-b to usb cable
Message 11 of 23
(1,424 Views)
It looks like Labview cannot recognize the pump.
Confirm the settings and run the following vi.
Message 12 of 23
(1,423 Views)
According to the manual if u r using USB the speed should be 115200, not 9600.
Message 13 of 23
(1,422 Views)
my pump doesnt let me change the baud rate manually to 115200. its just stuck at 9600.
Message 14 of 23
(1,418 Views)
 this is what I got when I ran the code.
Message 15 of 23
(1,416 Views)
i just managed to change the baud rate to 115200 now i get this error. what does it mean? how can i fix it?
Message 16 of 23
(1,413 Views)
That's a good sign, it shows that the pump responded but not what the code was expecting. Go back to the other examples and see if you can run them .
Message 17 of 23
(1,399 Views)
I've been trying with the other examples but the max baud rate it will go is 38400. I don't know how I can modify it to go up to 115200. I tried changing the settings of the pump to 38400 but that doesn't work either.  does anyone have a code that is compatible with my pump and the baud rate can go up to 115200?
Message 18 of 23
(1,369 Views)
you can change the speed by typing the proper Baud Rate just to test your connection
Message 19 of 23
(1,352 Views)
I did that but then it started to give me an error
Message 20 of 23
(1,347 Views)
