Connecting a Chemyx fusion 4000X Syringe pump to labview
Can you post the example modified? I can try to run that code
Message 21 of 23
(556 Views)
Message 22 of 23
(550 Views)
Accepted by topic author victoria1234
hey! so, i tried your modified example. now I don't get any errors every time I run it. but the pump doesn't really do anything every time I run LabVIEW. now when I check on instrument detected it appears *IDN? as an instrument. What else should I do to make the pump run by LabVIEW? Also, I validate the port on NI MAX and changed the baud rate to 115200. now, when I open visa test panels input/output it gives me an error when i click read and when I click read bytes.
Message 23 of 23
(531 Views)
