Connecting to a device connected to another pc
Hi there, I have a wavefront sensor (a camera basically) connected to a pc (lets call it "pc1"). I am able to read from camera using labview on pc1. HOWEVER I wish to connect to the camera via another pc ("pc2") connected the same network as pc1. Is there a way to do this? if not is there a way to connect the camera (which has only a usb output) to the network so that I could read from it like so?
Thanks in advance.
p.s the wfs is from Thorlabs if that's relevant..
(4,794 Views)
Pretty sure that is not possible. USB is a two way stream, so three devices using the same port will not work.
Only "solution" is to make a USB server application that communicates to the device that spreads its data over TCP\IP, UDP, or whatever.
(4,769 Views)
Accepted by JohnG9
If communication with the wavefront sensor uses VISA drivers, it may be possible to make it available on the network using VISA Server. Some USB devices create a virtual serial port, and you can share that port by activating VISA Server in NI MAX.
If the wavefront sensor appears to the PC as a camera, I don't believe there is a similar option "built in", but you can make your own server app. Since you are able to read from the camera on pc1 you can write a server app that runs on pc1 and listens for client connections. You would then implement a set of command messages from the client to start acquisition, stop acquisition, etc. You can write images to a shared variable or implement you own TCP-based messaging protocol by flattening the image to a string and transferring that to the client.
(4,761 Views)
Have you looked into USB-Network adapters? A google shows a number of them from a number of locations. Not sure, depending on the speed of your device (USB, USB-2 USB-3), whether this would be fast enough. Another possibility is running a program on PC1 and using Network Shared Variables to read the data from PC2.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(4,754 Views)
Does Visa Server allow both computers access to a device? From the quick glance at the documentation, it's made accessible from "another computer", not "other computers".
I guess it's not clear (to me) if you want the device to be available on several computers, or several computers at the same time.
(4,751 Views)
How about connecting to the other PC(pc1) via Remote Desktop?  If the information gets saved to a shared network area, then the data can be reviewed off-line at a later point.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,736 Views)
Have you thought about just running LabVIEW on PC1 and using remote panels to interact with LabVIEW from PC2?
33d28d1a58
=== Engineer Ambiguously ===
(4,714 Views)
