Connection Problem with cDAQ
hi everybody,
i have some problems with cDAQ9178.
First time i have connected it using USB it has worked good.
Then i have disconnected, and when i have tried to reconnect, pc hasn't communicated with it anymore.
Someone has had the same problem?!?!?!
Giovanni
(5,540 Views)
Giovanni,
did you try anoter USB port?
Reboot of the system?
What happens in NI MAX if you plug in the cDAQ?
Norbert
Norbert
Expert: Geometry
(5,526 Views)
i have tried another usb, and i have also restarted pc but nothing work.
NI MAX doesen't do anything. It doesen't work
(5,515 Views)
You do have power connected to the cDAQ? DO the LEDs indicate that the cDAQ is functional/busy?
Have you tried a different USB cable?
Norbert
Norbert
Expert: Geometry
(5,504 Views)
I've had the same problem with a card reader (SD, compact flash and so on).
It was the USB hub on the motherboard that had hung.
Shutting down the computer and unplugging it for a coupld of minutes reset it. Just restarting or shutting down the computer leaves enough voltage to keep it alive an locked.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,496 Views)
*double post*
Qestit Systems
(5,496 Views)
NI has an issue with USB3.0 controllers.
Try one of the USB2 ports. Also, if you'r using a hub, try to disconnect it.
http://digital.ni.com/public.nsf/allkb/49A8EC95510360F586257B09005B7AB1
Make sure the NI Device Loader service is running:
http://digital.ni.com/public.nsf/allkb/2E02F8EC5D0197928625758C005FFD8D
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(5,488 Views)
