Context menu with Dynamic Event and Array element
Accepted by topic author cassaniti
@cassaniti wrote:
i know it works with the whole array.. the fact is that i need it only on the digital element like in the example that I attach you here.. that is not working for me....
Post Heading Never said Digital Only, anyway here is modification to only get menu on Digital elements
Message 11 of 13
(1,125 Views)
Oh ok now I got the trick you use in order to get that done. Yes i didn't explicitly say about the digital value because I thought the first example was already explaining where the problem was. Thanks anyway!
Message 12 of 13
(1,123 Views)
@cassaniti wrote:
Do you mean like this (see version attached)? It doesn't change anything to me (LV 2015 SP1)
I don't have 2015 to test, on 2017 it appears to work, if I am sure of what you are asking for.
mcduff
Message 13 of 13
(1,108 Views)
