Continuous Analog Output with Hardware Timing
Hi Yatin,
1. So I should ignore elapsed time altogether and believe (for e.g.) that when I specify AO rate =100Hz, I get an output point every 1/100th of a second? and with AI rate =1kHz, the readings are at exactly 1/1000th of a second apart.
2. If so, why is elapsed time consistently indicating a rate half of what I specify for AO?
3. Is there a better way of time-stamping the data?
Thank you for your help,
Chanchala
Message 11 of 13
(999 Views)
Arrat data spreadsheet attached...
Message 12 of 13
(964 Views)
Data written to file attached (this was using the USB DAQPAD 6015)...
Message 13 of 13
(957 Views)
