Control with single impulse
I am using LabView to communicate with a Voltage Source (50kV) and some in and outputs.
I have an boolean which is true when the system detect a breakdown - voltage. The problem is that this boolean is only for a short time true, otherwise its false (only at the moment of the breakdown)
With the first true impulse, I would like to permanently control a relays with a true value.
Should I try to go with a RS Flip Flop or something like that?
Do you have any other suggestions for me?
Thank you very much!
Andy
(2,916 Views)
Accepted by Andutschi
Put the value in a shift register an OR it with the previous to keep it true after it is true once. Add a mechanism to reset.
(2,914 Views)
Thank you, works very well!
(2,867 Views)
