Controlling Motor RPM with PID control
Hi Iza,
@laz_2331 wrote:
Thank you GerdW.
Here are the corrections I made:
Used 250ms wait time,
Initialized shift register using tick count,
Adjusted the PID output limits
Applied a median filter to PV.
Sample output attached.
You should additionally post your code so others can learn from it.
The sample output looks quite ok now - maybe a little more tuning of PID parameters can improve the step behavior even more…
Message 11 of 13
(1,123 Views)
Here is the VI.
lza
Message 12 of 13
(1,115 Views)
Hi Iza,
much better.
Now you need to learn how to write "clean" LabVIEW code:
Message 13 of 13
(1,091 Views)
