06-30-2008 09:42 AM
06-30-2008 09:46 AM
Hi Heinen,
you can use TCP/IP functions to build a communication between your programs. See the shipped example to get more information about it.
Hope it helps.
Mike
06-30-2008 09:49 AM
Hello Mike S81,
Isn't TCP/IP something that has to do with network communication?
I want to use my programs on the same pc.
Thx 🙂
06-30-2008 09:51 AM - edited 06-30-2008 09:52 AM
Hi Heinen,
yes that´s right, but you can use it also to communicate between programs on the same pc, and the advantage is, if you need to use it later on two pc´s it´s simply possible. ![]()
Mike
06-30-2008 09:59 AM
