Convert 0 to "fail" and 1 to "pass"
... and this one, with the numeric input.
Message Edited by jcarmody on 03-24-2009 02:59 PM
Jim
Message 11 of 14
(858 Views)
One more option:
Index array on ['failed,'pass'].
Felix
Message 12 of 14
(838 Views)
That's probably what I would have picked. The "select" is dangerous because you get valid outputs for invalid inputs (e.g. inputs of -100 or +5,  would return a "passed" in Dennis's solution above. That's not good! :()
The solutions by Jim and Felix (image below) output an empty string if the input is out of range, which seems safer.
Message Edited by altenbach on 03-24-2009 05:58 PM
Message 13 of 14
(819 Views)
I actually picked up that way of coding from someone in this forum now having a 10k sign.
Felix
Message 14 of 14
(814 Views)
