Convert Labview 5.0 to Labview 8.5
Hello. Would someone please convert the old VIs in the library attached (possibly created with LabVIEW 5.0) to VIs which can be opened in LabVIEW 2009?
Just in case it might be useful to someone else, those are VIs which calls vcand32.dll functions in order to access Vector's CAN hardware like CANcaseXL for example. Those seem much easier to use than vxlapi.dll functions.
Thank you very much.
Message 81 of 152
(3,762 Views)
Attached are in 8.2. Can't say much for the quality of the code, though.
Message 82 of 152
(3,752 Views)
Can anyone help to convert this .llb from version 5.1 to 8.6? Appreciates.
Message 83 of 152
(3,721 Views)
Attached is in 8.2. Looks like it's an IVI driver, so I'm assuming you have the required DLL installed as well as the IVI Compliance Package.
Message 84 of 152
(3,714 Views)
Hi there,
Can anybody converts LabView 5.0 VIs into LabView8.6?
ThankYou
Message 85 of 152
(3,645 Views)
Attached in 8.2.
This is making use of a Action Engines
Message 86 of 152
(3,621 Views)
Thank you very much for sparing some time to solve my problem
Message 87 of 152
(3,611 Views)
Can somebody convert attached library from Labview 5 to Labview 8.6?
Thanx!
Simon
Message 88 of 152
(3,550 Views)
Attached is the driver in 8.2. It requires the lcltxxxx_32.DLL, as this is an IVI driver. If you haven't already installed it you will need to get and install the IVI Compliance Package. You may wish to get the 7.1 version directly from IDNET.
Message 89 of 152
(3,542 Views)
thank you! now everything is ok.
Message 90 of 152
(3,514 Views)
