Convert Labview 5.0 to Labview 8.5
hi
Please, Ineed help
I have someold examples of library made with an old labview version
I need helpto convert these files in labview 8.6
Message 91 of 152
(2,457 Views)
aydoganomer wrote:
hi
Please, Ineed help
I don't think these are going to do you much good. For one thing, they use Traditional DAQ. For another, the code is poorly written.  Your call.
Message 92 of 152
(2,440 Views)
Please can you convert Homer(8.6) and minesweeper(8.2) to version 8
The link is:   http://forums.ni.com/ni/board/message?board.id=170&thread.id=464763&jump=true
Message 93 of 152
(2,435 Views)
DO NOT HIJACK THREADS. This thread is for converting old code into newer versions of LabVIEW.
Please learn a little patience. Someone will get to you eventually.
Message 94 of 152
(2,432 Views)
Sorry
I saw that this thread had almost the same title as mine.
Your comments are well placed.
Message 95 of 152
(2,415 Views)
hello..
i am new to LV..
could someone please help me convert these vi into 8.6 version?
these were written in 8.2 and for some reason i can't open them in 8.6.
thanks a lot!
happy new year!
Message 96 of 152
(2,334 Views)
Those VIs were not written in 8.2. They are in LabVIEW 4.0 which is very clearly stated when you attempt to open one with 8.6. Here they are in version 7.1. Hope you have the missing dll.
Message 97 of 152
(2,327 Views)
No, they are actually written in LV4.0.  You will need someone with a version of LV between versions 6.0 and 8.2 (inclusive) to open them and save the files.  Then you will be able to open them in LV 8.6
Unfortunately, I don't have LV8.2 on this PC to do it for you.
How to Upgrade or Revert a VI to a Different Version of LabVIEW
EDIT:  Dennis came through with the conversion I while was composing the message.
Message Edited by Ravens Fan on 01-07-2010 11:22 PM
Message 98 of 152
(2,325 Views)
thanks for your help!
Message 99 of 152
(2,313 Views)
Could somebody convert attached files from LV5.1.1 to LV 8.6 or 9 ?
Thanks!
Simon.
Message 100 of 152
(2,276 Views)
