Convert PNG to 300pdi
I want
to export a graph's image to a 300pdi-png (printing). Here's what I do:
First I export the graph to a png with the standard LV-VI. I re-open the file, locate the IHDR-Header, shift the index by 17 (which is the end of the IHDR) and place the pHYs-Header (from a 300pdi-PNG created by Photoshop)in between the IHDR and the IDAT,  as required. (See Snipet; hope you don't mind the german captions ^^)
So far
so good, but the file gets corrupt after my modifications....guess I've done some mistakes here.
Greets,
Stoney
Message Edited by Stone-D on 03-24-2010 06:20 AM
Message 1 of 8
(4,315 Views)
At the first, try to set "prepend array or string size? (T)" of the Write to Binary File primitive to false (its true by default), because this added 4 additional bytes at the beginning of the file and png header gets corrupted.
Andrey.
Message 2 of 8
(4,288 Views)
Should it not be dpi instead of pdi
Message 3 of 8
(4,286 Views)
Hmmm... "Per Dot Inch" also not so bad. But "ipd" - this will be definitoively totally wrong!
Message 4 of 8
(4,284 Views)
Just wanted to confirm that it means the same irrespective what the name is.:smileywink:
Message 5 of 8
(4,280 Views)
ups, my bad....
Andrey.
Thanks, but the file is still corrupt...
Message 6 of 8
(4,249 Views)
Not sure if other parts of the header should be changed or not (may be some offsets values should be corrected).
You have three possibilities in general:
1. Check byte to byte that your new file still compliant with  RFC2083.
2. Use ImageMagick (something like "convert -units PixelsPerInch -density 300 inFile.png outFile.png")
3. Use  libpng (as dll - this can be hard if you haven't experience with using external code in LabVIEW)
Andrey.
Message 7 of 8
(4,233 Views)
Accepted by Stone-D
omg, just found my error.............The string constant which contains the dpi-header wasn't set to hex...
Message 8 of 8
(4,226 Views)
