Convert Special ASCII characters to equivalent Hex code
I am trying to convert special ascii characters that are being read from a serial port, to a data type that I can manipulate. To create this scenario, create a empty string constant, then right click on it and change type to "Hex". Now enter a value in it, say 287F. If you right click again and change the display to "Normal", you should see this value "(", which are special ascii characters.
What I am trying to do is to convert this incoming data into a format where I can manipulate the data to read the binary equivalent of this data. For example, for the incoming data of "287F", I want to be able to convert it to "0010 1000 0111 1111"
I have not been able to find any function that would convert this type of data. Am I overlooking something that is very obvious?? Or is this not possible to do it in Labview. Please advise.
Thanks in advance.
Shoab
(6,509 Views)
Use String to Byte Array from the String->Conversion Palette.
Then change the radix on the byte array indicator to show binary.
(6,493 Views)
ASCII is only defined for the first byte (0-127), your code is not ASCII, it's Unicode.
The following code should do the trick.
22729i094A68CDF9589BC1
Ton
My LabVIEW Ideas
(6,472 Views)
Accepted by Shoab
If it is always exactly 2 Bytes, typecast to U16 and either format to string as binary or set the display format of the U16 to binary.
(6,460 Views)
(6,435 Views)
