Convert array into Global Variable??
I'm translating a program from HP Vee to Labview 7.0
I have 7 numeric entries to a 1-D Array, then, I would want to convert this array into a global variable I will be able to use in other VIs, this thing at the image of the Build record function + Set variable function in HP Vee.
Is it possible??
(3,033 Views)
Sure you can make a global variable of an array.
I would recommend looking at the online LabVIEW tutorials [links below removed; articles no longer available]
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,022 Views)
