Convert fragment string from File to values
Wich function use to convert fragment string to values?
I have this string in File:
Instrument:NI-DAQ;Date:01-10-2008;
Quantity:Voltage[V];
Results: 1.23,3.45,5.65,6.89,...;
And i need values - 1.23,3.45,5.65,6.89
(4,476 Views)
Hi Cris,
open the context help, then move the mouse pointer of all those functions in the string functiosn palette!
I would use MatchPattern to search for a keyword (like "Results:" in your case), followed by SpreadsheetStringToArray with proper format string, delimiter and array constant inputs…
(4,453 Views)
Accepted by crisdragon
 Hi crisdragon,
You have to use the native LabVIEW file and string API.
I made you an example.
Hope this help.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(4,451 Views)
Spreadsheet String to Array followed by Array Subset might work if the header format is well defined. You may need to change the delimiters.
Lynn
(4,407 Views)
sabri.jatlaoui
You are awesome. I have one question how make one Array Control and Indictator at the same time like in example?
(4,398 Views)
 Hi crisdragon,
Right click on the input, output or wire you want and choose create control or indicator.
Godd luck.
(4,378 Views)
