Convert string array to enum at runtime
Could you give me an litte example?
Message 11 of 24
(6,869 Views)
yes - why not?
Message 12 of 24
(6,868 Views)
Try this:
Add the sheet names to the enum control, and they will be converted to strings
Message 13 of 24
(6,865 Views)
thanks.
I'm also confused. The output is an array, and should be an enum.
Message 14 of 24
(6,857 Views)
You said you want the user to select a sheet name stored in an enum, and that would drive the active displayed worksheet in excel. Assuming you are using the Report Generation Toolkit to do this, the input to the Excel Get Workstheet.vi is a string:
So you would need to format the selected enum value into a string:
Message 15 of 24
(6,855 Views)
Yes that's the way. But I still haven't got the enum. The output from the snip was an array.
Or am extremely stupid ? ðŸ˜‰
Message 16 of 24
(6,854 Views)
I think I understand now. You are pulling in the excel sheet names into labview as an array of strings. You then want to populate an enum control with those strings, and have the user select one to change the active worksheet?
There is no way to edit the values of an enum at runtime that I am aware of.
Message 17 of 24
(6,852 Views)
Accepted by topic author Michael.Koppelgaard
As Ben previously mentioned an enum can only be edited at edit time, is fixed a runtime. You could use your "read in array of names" to populate a  ring control, then use the output of that to index the original array of names to get the desired name to select the active sheet.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 18 of 24
(6,841 Views)
I didn't think about it that way. That would certainly work. Note to self...
Message 19 of 24
(6,834 Views)
Great !
Would you be kind to make a small example ?
Message 20 of 24
(6,818 Views)
