Convert to Graph help
Message 1 of 37
(6,950 Views)
WHat have you tried so far and how successful were you? its often best to say what you have tried when asking for help
hope we can help tho
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 37
(6,945 Views)
I would suggest to use an IndexArray function on those gray level data.
Index the interesting row of data and display it in a graph...
Message 3 of 37
(6,942 Views)
Message 4 of 37
(6,934 Views)
Hi Learner,
do you already have a graph? (Maybe you should name it correctly IntensityGraph...)
- Enable cursors for the intensity graph.
- Edit the cursor appearance to show lines.
- Read the cursor position.
- Index the corresponding row/column and display it in a graph...
Why don't you atach a VI with your current approach?
Message 5 of 37
(6,932 Views)
Hi Gerw,
The intensity graph you refering to is the image with white area?
Message 6 of 37
(6,928 Views)
Hi Learner,
I'm referring to the upper image of your first post. I would use an IntensityGraph to display it...
Message 7 of 37
(6,918 Views)
Message 8 of 37
(6,913 Views)
Hi Learner,
it's the same as suggested before, simply change the cursor style...
Message 9 of 37
(6,910 Views)
Message 10 of 37
(6,900 Views)
