Convert to Graph help
Hi Learner,
yes it's possible even without a cursor. When you already know the ROI you can simply index your image data array...
- Is there a reason why you only post images instead of just writing text messages?
- Is there a reason why you don't attach a VI with some sample data to show what you have done already?
Message 11 of 37
(3,573 Views)
Message 12 of 37
(3,558 Views)
Hi Learner,
ROI...
- Live video isn't displayed in an intensity chart.
- When you have that manufacturer code, then it's fine. I don't have it, so no further comments...
Again:
Why do you insert pictures of your messages instead of just typing text here?
Message 13 of 37
(3,543 Views)
Hi Gerw,
This is a screen shot of the code that is used for "live video". Hmm... I am still trying to capture it.
Message 14 of 37
(3,537 Views)
Hi Learner,
ok, so in your case "live video" is shown on an intensity graph. I should have written "usually"... (And it took you 14 messages to actually show a small snippet of the block diagram...)
It's just a 2D array. You can do anything you want with it: saving to file, doing analysis, show rows/columns on other graphs...
Message 15 of 37
(3,531 Views)
Hi Gerw,
I apologise for posting the image really late. I will post back when I have some progress thanks!!!!
Message 16 of 37
(3,539 Views)
Hi Gerdw,
How can I Read the cursor position?
Message 17 of 37
(3,523 Views)
Hi Learners,
you will find the cursor position(s) in the property nodes of the intensity graph!
Message 18 of 37
(3,515 Views)
Hi Gerdw,
Is it found in properties-> Cursors?
Message 19 of 37
(3,509 Views)
Hi Learner,
yes...
Message 20 of 37
(3,507 Views)
