Convert to Graph help
Hi Gerdw,
How can I get that position value and pass it into index array. I have gotten the cursor position to show in front panel.
Message 21 of 37
(2,133 Views)
Hi Learner,
so you already got the Cursor Position with it's X and Y value?
When you don't use scaling of the X/Y-axes you can just use the cursor position values to index your data array...
Message 22 of 37
(2,130 Views)
Hi Gerdw,
Yes, I already got the Cursor Position with it's X and Y value at the front panel.
I want to get this value to connect to index array automatically.
I do not undestand what you mean"When you don't use scaling of the X/Y-axes you can just use the cursor position values to index your data array...".
Message 23 of 37
(2,124 Views)
Hi Learner,
I already told you to use property nodes... Did you try this?
Message 24 of 37
(2,120 Views)
Hi Gerdw,
Sorry I misinterpreted your post.
Message 25 of 37
(2,117 Views)
Hi Learner,
as long as you don't apply scaling to the axis values it's ok...
Message 26 of 37
(2,113 Views)
Hi Gerdw,
Scaling is a properties option?
Message 27 of 37
(2,111 Views)
Hi Learner,
yes, you can scale the axis values.
Either right-click your graph and open the properties dialog (look for "offset" and "multiplier") or by proeprty nodes...
Message 28 of 37
(2,109 Views)
Hi Gerdw,
This is the setting for intensity graph.
May I know the purpose why there is a need not to apply scaling to the axis values?
Message 29 of 37
(2,106 Views)
Hi Learner,
right now the scaling is off (multiplier=1, offset=0). So the cursor position is equal to the index of the array element.
When you apply some other scaling you will also get scaled cursor positions. Then you have to calc from cursor position back to element index...
Message 30 of 37
(2,100 Views)
