Converting String to Array
Hello everyone ..
I am making a program to read data from the buffer of 2182A (nanovoltmeter) using VISA (SCPI Programming). Now I can get the data from the buffer but it is in the form of a string. Can you tell me how I can convert this into an array (separate out each reading) (screen shot of my test data is attached)..
Also this is a small sweep of only 10-11 steps. In measurement the sweep might be more than a 100 steps so please keep this mind as well...
(4,153 Views)
Hi Hamza,
use SpreadsheetStringToArray function with a 1D array constant at the lower left input and a comma as separator char…
(4,150 Views)
And if you used the instrument driver as recommended in your other thread (or looked at the block diagram), you would not have needed to post this question.
(4,129 Views)
Accepted by HamzaZG
Found my solution .. Posting it here for everyone maybe it may be useful for someone
(3,964 Views)
