10-23-2017 07:56 PM
I worked on the VI all day yesterday and have done for the past few weeks. when I closed the program I got a message saying "cannot load Help Information..." and then when I tried to reopen the VI I was greeted with the error message above. The corrupted file is attached below. The fie was about 300kb and since its been corrupted its now only 2 kb. I haven't changed any code or moved any files I simply ran the program and now its corrupted. Any help as to what happened or how to fix this would be greatly appreciated!
Solved! Go to Solution.
10-23-2017 08:17 PM - edited 10-23-2017 08:18 PM
Restore from your source code control repository. Here is the contents of the file you attached " 12:36:27.4, 21.849887, 21.779021, 21.767071, 21.741444, 21.415369, 21.422600, 21.331456, 21.565021, -0.106434 12:36:27.5, 21.857221, 21.792447, 21.771514, 21.749580, 21.422012, 21.429422, 21.346561, 21.573691, -0.125244 12:36:27.8, 21.852693, 21.793580, 21.771554, 21.749034, 21.418742, 21.429604, 21.340524, 21.567492, -0.108506 12:36:28.8, 21.861184, 21.799176, 21.777462, 21.758391, 21.425663, 21.439769, 21.343790, 21.574918, -0.096765 12:36:29.8, 21.852381, 21.793165, 21.771300, 21.752643, 21.417159, 21.431246, 21.340737, 21.571274, -0.115421 12:36:30.8, 21.869663, 21.795541, 21.772374, 21.745867, 21.422946, 21.433367, 21.339457, 21.573802, -0.103411 12:36:31.8, 21.870679, 21.795380, 21.782172, 21.754471, 21.425516, 21.436606, 21.342995, 21.571735, -0.095613 12:36:32.8, 21.862094, 21.794974, 21.773433, 21.752602, 21.427673, 21.436620, 21.335978, 21.566505, -0.069407 12:36:33.8, 21.867965, 21.803489, 21.781149, 21.762187, 21.432960, 21.444468, 21.346575, 21.576570, -0.083098 12:36:34.8, 21.870135, 21.800365, 21.775796, 21.755865, 21.426144, 21.445262, 21.338496, 21.562535, -0.053900 12:36:35.8, 21.870007, 21.809993, 21.783206, 21.764166, 21.431352, 21.443555, 21.342022, 21.568790, -0.065344 12:36:36.8, 21.861941, 21.803502, 21.778871, 21.759708, 21.429308, 21.439628, 21.334911, 21.567633, -0.061145 12:36:37.8, 21.872751, 21.808035, 21.786698, 21.765379, 21.439386, 21.443200, 21.338748, 21.571079, -0.049545 12:36:38.8, 21.869120, 21.800443, 21.781223, 21.761815, 21.434544, 21.438917, 21.337799, 21.567708, -0.058244 12:36:39.8, 21.868881, 21.804454, 21.790794, 21.760833, 21.437498, 21.448446, 21.342993, 21.566529, -0.042850 12:36:40.8, 21.864596, 21.801825, 21.788043, 21.763992, 21.435016, 21.445186, 21.331635, 21.569743, -0.038437 12:36:41.8, 21.873817, 21.797389, 21.785756, 21.755318, 21.427402, 21.439007, 21.336134, 21.556869, -0.048330 12:36:42.8, 21.866922, 21.798963, 21.785801, 21.765002, 21.432187, 21.437169, 21.333774, 21.561771, -0.047675 " Apparently you overwrote the vi with data
10-23-2017 08:34 PM
Hey Jeff,
Thanks heaps that makes a lot of sense. I've restored a previous version and its all good now thanks so much for your help!!
10-23-2017 11:17 PM
@cwel wrote:
Hey Jeff,
YAHOOOEY!!! Someone who actually had a backup to restore from. Wearing a safety harness BEFORE you crash is always the best approach. 🙂 Most people who come here to lament about a corrupt VI usually didn't have the foresight to make backup copies and/or commit them to a repository.
Good for you!
