Corrupt VI
 I worked on the VI all day yesterday and have done for the past few weeks. when I closed the program I got a message saying "cannot load Help Information..." and then when I tried to reopen the VI I was greeted with the error message above. The corrupted file is attached below. The fie was about 300kb and since its been corrupted its now only 2 kb. I haven't changed any code or moved any files I simply ran the program and now its corrupted. Any help as to what happened or how to fix this would be greatly appreciated!
(3,318 Views)
Accepted by cwel
Restore from your source code control repository. Here is the contents of the file you attached " 12:36:27.4, 21.849887, 21.779021, 21.767071, 21.741444, 21.415369, 21.422600, 21.331456, 21.565021, -0.106434 12:36:27.5, 21.857221, 21.792447, 21.771514, 21.749580, 21.422012, 21.429422, 21.346561, 21.573691, -0.125244 12:36:27.8, 21.852693, 21.793580, 21.771554, 21.749034, 21.418742, 21.429604, 21.340524, 21.567492, -0.108506 12:36:28.8, 21.861184, 21.799176, 21.777462, 21.758391, 21.425663, 21.439769, 21.343790, 21.574918, -0.096765 12:36:29.8, 21.852381, 21.793165, 21.771300, 21.752643, 21.417159, 21.431246, 21.340737, 21.571274, -0.115421 12:36:30.8, 21.869663, 21.795541, 21.772374, 21.745867, 21.422946, 21.433367, 21.339457, 21.573802, -0.103411 12:36:31.8, 21.870679, 21.795380, 21.782172, 21.754471, 21.425516, 21.436606, 21.342995, 21.571735, -0.095613 12:36:32.8, 21.862094, 21.794974, 21.773433, 21.752602, 21.427673, 21.436620, 21.335978, 21.566505, -0.069407 12:36:33.8, 21.867965, 21.803489, 21.781149, 21.762187, 21.432960, 21.444468, 21.346575, 21.576570, -0.083098 12:36:34.8, 21.870135, 21.800365, 21.775796, 21.755865, 21.426144, 21.445262, 21.338496, 21.562535, -0.053900 12:36:35.8, 21.870007, 21.809993, 21.783206, 21.764166, 21.431352, 21.443555, 21.342022, 21.568790, -0.065344 12:36:36.8, 21.861941, 21.803502, 21.778871, 21.759708, 21.429308, 21.439628, 21.334911, 21.567633, -0.061145 12:36:37.8, 21.872751, 21.808035, 21.786698, 21.765379, 21.439386, 21.443200, 21.338748, 21.571079, -0.049545 12:36:38.8, 21.869120, 21.800443, 21.781223, 21.761815, 21.434544, 21.438917, 21.337799, 21.567708, -0.058244 12:36:39.8, 21.868881, 21.804454, 21.790794, 21.760833, 21.437498, 21.448446, 21.342993, 21.566529, -0.042850 12:36:40.8, 21.864596, 21.801825, 21.788043, 21.763992, 21.435016, 21.445186, 21.331635, 21.569743, -0.038437 12:36:41.8, 21.873817, 21.797389, 21.785756, 21.755318, 21.427402, 21.439007, 21.336134, 21.556869, -0.048330 12:36:42.8, 21.866922, 21.798963, 21.785801, 21.765002, 21.432187, 21.437169, 21.333774, 21.561771, -0.047675 " Apparently you overwrote the vi with data
(3,302 Views)
Hey Jeff,
Thanks heaps that makes a lot of sense. I've restored a previous version and its all good now thanks so much for your help!!
(3,290 Views)
@cwel wrote:
Hey Jeff,
YAHOOOEY!!!  Someone who actually had a backup to restore from.  Wearing a safety harness BEFORE you crash is always the best approach.  🙂  Most people who come here to lament about a corrupt VI usually didn't have the foresight to make backup copies and/or commit them to a repository.
Good for you!
Bill
CLD
(Mid-Level minion.)
(3,267 Views)
