Counting white pixels in a roi
Hi to all.
I Have an inspection image an a template.
The template is inside inspection image.
I use pattern matching to know the template position (ROI) in the inspection image.
Know I would like to count the white pixels in that found ROI.
How can I do that?
Thanks.
(4,025 Views)
Get the pixel array from your ROI and Check which ever is white based on your pixel value and count the same
(4,020 Views)
Accepted by Alvaro.S
Go to Help->Find Examples->Search for Histogram.
Histogram will give you the array of number of pixels(y) with intensities as x.
uday
(4,015 Views)
Yes, the problem with histogram.vi is that it calculates pixel information for whole image and I need just for a ROI.
(4,005 Views)
If you checked the example which i pointed it gives the Histogram in the ROI and not the entire image.
Ref: http://www.ni.com/example/30677/en/
uday
(4,000 Views)
Try to share the Code which you tried. so that better guidance can be given based on your view.
(3,985 Views)
