Create new vi by clicking on a button in front panel
BTW, just to give you an idea.  You're still using a dynamic call to your VI's.  Is there a reason for that?  Using dynamic calls to VI's increases the difficulty of your project where in 75% (just a number to indicate that is is a lot) of all cases dynamic calls are not needed.
Dynamic calls to me is only needed in some very special cases !  Please don't make it to hard on yourself
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 11 of 13
(656 Views)
I have one doubt how to create buttons in front panel so that when we click that buttons the required action will be done by block diagram.
Message 12 of 13
(533 Views)
this is an ancient tread that has already be marked as solved. Please start a new thread with a new question.
This seems like a very basic question. Have you done any introducuctory LabVIEW tutorials? Looked at some examples? What does the program do? What are the "required action"? What code design pattern are you using?
Please write a few more sentences explaining what you want to do and maybe even attach your coding attempt.
Message 13 of 13
(507 Views)
