Custom Run Time Menu (.rtm) for a tree control doesn't appear in LV executable
Can't say that this has been solved. I'm running into the same problem with LV 2013 SP1 at least for enums and Graphs. Workaround works though.
Message 11 of 12
(609 Views)
I thought I had this problem, but it turns out I had the run time setting specifically hiding the menus They were there, but I had told the application not to show them. Hope this helps!
(I had the second box from the top left unchecked. . .)
Image result for vi properties
Message 12 of 12
(527 Views)
