DAQ Assistant
After.  Is that the correct protocol?
Message 11 of 13
(858 Views)
Yes.  After is correct.  DAQmx installer needs to know what LabVIEW versions are installed to be able to install into them.
I have no idea why you are still having problems then.
Message 12 of 13
(848 Views)
It appears that the problem stemmed from the fact that my colleague installed NI-DAQmx 15.1.1 prior to me installing NI-DAQmx 9.4.
We decided to uninstall and reinstall everything.
However, at the end of the NI-DAQmx 9.4 intallation the following message appears:
Application Error
An error has occurred and NI Update Service must exit. If the issue persists after restarting NI Update Service (Start»All Programs»National Instruments»NI Update Service), contact technical support at ni.com/support.
I have uninstalled and reinstalled the NI-DAQmx 9.4 three times now, but the message persists.
Futhermore, the DAQ Assist icon does appear if I run LabVIEW, but the following error appears immediately after I specify the channel:
HelpAssist.dll not found.  Reinstall NI-DAQmx.
Again, I have been through the process three times now.
Plese advise.
Bunny
Message 13 of 13
(829 Views)
