DAQ Assistant
I am a new user for Labview.  I couldnot able to find DAQ Assistant.  Please suggest me some ideas to find out the same.
or Do i need to connect my Laptop to the Hardware so that i will get the DAQ Assistant in my software.
Please help me
Deepu
Message 1 of 13
(7,610 Views)
Accepted by Deepukj90
The DAQ Assistant is not installed with LabVIEW, but with DAQmx. If you have installed drivers for a DAQmx device, this will install the DAQ Assistant in LabVIEW. It is found on the palettes in Measurement I/O>>DAQmx - Data Acquisition.
Message 2 of 13
(7,604 Views)
What version of LabVIEW? You must install an appropriate version of DAQmx after you install LabVIEW.
Message 3 of 13
(7,603 Views)
Thanks a lot. It worked for me. 🙂 🙂
Message 4 of 13
(7,494 Views)
hi
I have the same problem that the daq assisetant button is missing.
The problem detall is similar to the above. When I click on the function palette, the " daq assistant" button does not exist on the category under express>input.
I cannot find it on the measurement I/O category either.
I am running on
win 7 64bits
labVIEW 2012 (Ver 12.0f3)
NI-DAQmx Device Driver 9.8.0f3
I already deal with it by different reinstallation order. Unfortunately, the problem is still not yet resolverd.
Thank you.
Message 5 of 13
(7,328 Views)
It is unclear.
Did you install DAQmx AFTER installing LabVIEW?
Did you restart LabVIEW after installing?
Did you reboot your PC after installing?
Message 6 of 13
(7,308 Views)
I have just went down this road without success.  I still cannot find tthe DAQ Assistant.  Anyyone have any other suggestions?  I am working on a company machine.  We used to have the DAQ Assistant on another machine.  I went through this thread and as far as I know all the suggected drivers have been downloaded. However, the DAQ Assistant is still missing......
HELP!!!
Message 7 of 13
(7,007 Views)
Please be specific. You haven't told us the version of either LabVIEW or DAQmx. You should know exactly what was installed.
Message 8 of 13
(6,995 Views)
LabView 8.6
DAQmx - 9.4
I also have on hand DAQmx - 9.1, but I installed 9.4.
Please advise.
Message 9 of 13
(6,972 Views)
That combination should work according to http://digital.ni.com/public.nsf/allkb/B40B0F539991EFDE86257E4C0080D0C5
But you still need to answer the questiod,  Did you install DAQ mx AFTER installing LabVIEW?
Message 10 of 13
(6,961 Views)
