DAQ Task in not available in student version?
Hello at all,
im trying to do something with the DAQmx Task.
But it is not in my function - express - input available, as you see on the picture:
Thanks for your help.
(3,313 Views)
You need to install the DAQmx driver. Did you do that after installing LabVIEW?
(3,309 Views)
No..but i found this download, is it correct?
http://www.ni.com/download/ni-daqmx-15.1/5617/en/
(3,298 Views)
Accepted by ms_hawk
Yes.  Download and install that.  It will add the DAQmx support to whatever LabVIEW installs you have.
(3,279 Views)
