DAQ VI templates - how to get them
lookinng through LabView core 2 I've noticed DAQ VI templates (please, see the snapshot below), that aren't present in my installation.
How can I get them ? Or they are merely custom templates ?
Pavel
(3,102 Views)
Do you have NI DAQmx installed on your machine?
Note: You have to install all drivers AFTER the development environment to be able to access the API in that development environment.
Norbert
EDIT: I've just seen that in my 2015 installation, i don't have these DAQ templates either (though i have DAQmx availble). I find it possible that with newer versions of LV/DAQmx these templates were removed. There are (with 2015 and i think already with 2014) some DAQmx based template PROJECT available though....
Norbert
Expert: Geometry
(3,099 Views)
Yes, here is snapshot of Start/LabView folder:
(3,086 Views)
