DAQmx 8.8 not exporting channels
Hmmm. Thanks for responding Dennis. As shown in my capture, I obviously have scales, but export doesn't see them...
Richard
Message 11 of 22
(1,938 Views)
Strange. What does the initial screen look like where it says 'Welcome to Configuration Export Wizard'? Mine says that the wizard exports configuration data for DAQmx 8.8, NI-488.2, and NI-VISA 4.4.
Message 12 of 22
(1,930 Views)
Yep, mine says the same thing, plus NI-Motion.
Another thing I just noticed was, when I check the ..By Product button, it says I have 0/0 DAQmx, even through it shows DAQmx. I can click it, but nothing happens, and I can't make an export based on clicking that one button.
Richard
Message 13 of 22
(1,908 Views)
That is the same as I was getting.
Message 14 of 22
(1,893 Views)
What version of MAX are you guys working with? I'm working with 4.5.1 and am not seeing that same problem. Installing the latest DAQmx or NI-VISA will reinstall the latest version of MAX.
ColeR
Field Engineer
Message 15 of 22
(1,885 Views)
Bryan,
Did you ever get any resolution to this?
Richard
Message 16 of 22
(1,769 Views)
You could always save this to a global and rewrite them
Message 17 of 22
(1,761 Views)
Thanks Jeff. Yes, there are work arounds, but it's no substitute for the button working in the software.
Richard
Message 18 of 22
(1,759 Views)
True-  It sounds like you should reinstall DAQmx.  If the LabVIEW hooks work and the MAX functionallity is missing its gotta be a corrupted file somewhere.  The point of trying the LabVIEW functions was meant to point toward the offending API that is not playing nice.
Message 19 of 22
(1,748 Views)
Sorry to say, not yet.
I am actually dealing with tech support right now dealing with this.  They did tell me a work around that kind of works.
If you go to C:\documents and settings\all users\application data\national instruments\max and copy that directory to a new machine there is a chance it will be recognised on the new machine.
I had a motherboard die and the above seemed to work.  But I cannot export the data from the new machine either.  So I am waiting for a response from the support guys.
Message 20 of 22
(1,741 Views)
