DAQmx Analog Output at 1 kHz is "glitching"
Hi all.  Just closing the loop on this.  I tested it, and can confirm that using  Hardware-Timed Single Point Mode solved the crux of my problem, which was the analog output performance in my control loop.  I realize there are other issues with my example code, and thanks for everyone's additional tips.
http://www.medicollector.com
Message 11 of 11
(96 Views)
