DAQmx is not visible in the Measurement I/O palette
Dear All,
I am also facing similar problem. I am not able to see NI Daqmx in Labview.
Labview version: Labview-8
Details of NI-daqmx installed is given in following images,
But i am unable to find NIdaqmx pallete. Please see image below,
Please guide me to get solution to this problem.
Thanks & Regards
Message 11 of 22
(6,729 Views)
DAQmx 9.6 is not compatible with LabVIEW 8.X.  LabVIEW 2009 is the oldest version it supports.  You are going to have to find an older version of DAQmx to work with LabVIEW 8.X.
See this article for more information:DAQmx and LabVIEW Version Compatability
GCentral
Message 12 of 22
(6,721 Views)
Hi Crossrulz,
yes there was version incompatibility between Labview-8 and NI-DAQMX 9.6. I removed NIDAQMX using Add/Remove programs and installed NI-DAQMX- 8.5. Now i am able to see NI DAQMX pallette in labview!
Abhishek.
Message 13 of 22
(6,704 Views)
Hope it works for me, downloading now 34%. have the same issue.
Message 14 of 22
(6,608 Views)
Hi every body,
I have a problem, I downloaded the Daqmx 9.8 and installed it but I do not have the Analog Input and Analog Output palette. My lab view is 2013. what should I do?
Message 15 of 22
(6,547 Views)
@vahhab wrote:
Hi every body,
Sounds like you are still used to Traditional DAQ.  DAQmx is mostly made up of Polymorphic VIs.  Drop a DAQmx Write down on your block diagram.  You will notice a drop down menu underneath your node.  Now marvel at all of the functions you can do.  In short, the DAQmx Write and DAQmx Read will both handle any type of DAQ you need (analog input, analog output, digital in, digital out, counter in, counter out, etc.).
GCentral
Message 16 of 22
(6,539 Views)
You have the correct palette for DAQmx. There is no such thing as an Analog Inpur or Analog Output palette. Perhaps you are confusing DAQmx with the obsolete traditional DAQ palette. That had those palettes. If you have old code with traditional DAQ functions, you should be replacing them with DAQmx.
Message 17 of 22
(6,538 Views)
Thank you very much guys.
Message 18 of 22
(6,532 Views)
It seems that everybody's issue with the DAQmx installation is a valid one..
There is a distinct difference between installing LabVIEW using the DVDs (Development Suite in my case) and downloading LabVIEW and installing the drivers as an additional step thereafter.
I have experienced the same problem as the others and did follow the appropriate instructions posted in several threads and knowledge base.  MAX reports the correct version for DAQmx ADE Support (9.6.2 in my case with LV2012).  However, the pallette is void of any DAQmx on one of the computers.
There is definitely something wrong with the DAQmx installation or link to LabVIEW.  I have installed NI software products 100s of times.  I must have installed LabVIEW 2012 on at least 20 different PC's over the past year, using both the DVDs, downloads, betas, etc..  On various versions of Windows and Linux.  I would not expect to run into a strange issue as this one today, which is why I searched this topic...  Plus the fact that many have reported issues with something that should be very straightforward should bring to light the fact that something is wrong somewere...
The actual issue was the DAQmx folder missing from vi.lib folder.   I resolved the issue manually.  😉
Spoiler
meaning that I simply copied the DAQmx folder from one machine to the vi.lib folder of the machine which was giving me issues...
Message 19 of 22
(6,440 Views)
"Drop a DAQmx Write down"----I am an installer fo the software and have no clue as to what that means. I believe the problem the engineers are having here with the measurment I/O palette not containing analog input is that they were use to using an older version of labview and have jumped to 2015. Can you explain to me what " Drop a DAQmx Write down " is? Thanks..Tim
Message 20 of 22
(4,824 Views)
