DAQmx is not visible in the Measurement I/O palette
That means drag the DAQmx Write function from the pallete and drop it onto your block diagram.
If you have DAQmx installation problems, then you probably won't see that palette.  Which is what most people in this thread were having issues with.
Message 21 of 22
(1,561 Views)
Thanks, was able to clarify..appreciate this..Tim
Message 22 of 22
(1,518 Views)
