 ken007
			ken007
			05-30-2017 07:44 AM
Hi all, I have connected same source to 2 different flap top module as shown in the pictures. Both give a different results.
What make this different and which module should I refers? Thanks
 aputman
			aputman
			05-30-2017 11:02 AM
Which one is showing the correct data?
05-30-2017 11:08 AM
I'm not sure which one is correct but the graph at the bottom in picture "1" is close (not exactly the same) to result simulated in Dasylab.
Looking for some better picture/explanation on that.
 aputman
			aputman
			05-30-2017 11:15 AM
If you aren't sure which one is correct.....
Since you are only simulating a signal, you'll need to give more information about what it is that you are trying to simulate in order for anyone to help you since we have no way of knowing what is the correct waveform.
 Henrik_Volkers
			Henrik_Volkers
			05-30-2017 12:13 PM
Have looked into the help files? Usually they should give a hi´nt, formular or link to a source/standard lib on how the windowing is performed.
