DSC Tutorial Custom Periodic I/O Server Problem
Hi all,
I'm having trouble seeing the Input Flowrate [GPM] I/O data item for my Tank1 I/O server in the NI Distributed System Manager. I have deployed the project library and followed all the steps in the 'Getting Started with the LabVIEW Datalogging and Supervisory Control Module' tutorial, but I only see the server statuses of Active, Error Code, Error Message, and server type under the Tank1 folder (image1).
Image 1
The Input Flowrate [GPM] is visible in the project library's View I/O window, but not in the Distributed System Manager (image2).
Image 2
Any suggestions on what might be causing this issue or how to resolve it?
Additional info:
LabView 2022 Q3 (32bit)
Thanks in advance,
The Kernel
(1,651 Views)
Hello Kernel, I'm having the same issue with a project for college and 90%+ of classmates are encountering same issue. Does anyone have a fix before project deadline of next Friday?!!
(1,595 Views)
May i see your I/O Server?
(1,487 Views)
