DSS Fatal Internal Error "memory.cpp" line 638
Hi!
Has anyone encountered the following problem:
Fatal Internal Error : ”memory.ccp” , line 638
This error occurs when I am using DSS and making changes in the polymorphic settings for reading/writing in DSS.
A picture is also attached.
Regards
Idriz Zogaj
Application Engineer
Cool Engineering AB
www.cool-engineering.se
Idriz "Minnet" Zogaj, M.Sc. Engineering Physics
Memory Profesional
direct: +46 (0) - 734 32 00 10
http://www.zogaj.se
(2,953 Views)
Idriz;
There is some information about "Fatal Internal Errors" involving "memory.cpp" in the following page:
LabVIEW Internal Errors (Failure in XXX.c / XXX.cpp at line YYY)
This should give you a good starting point.
Regards, Enrique
www.vartortech.com
(2,949 Views)
