Daqmx assistant cannot wire output
I did not have the newest daqmx. So I downloaded via your link and installed but still get the same behavior.
Message 11 of 13
(1,220 Views)
Accepted by topic author icemaker
Hi Icemaker,
We could spend a lot of time trying to find the issue with the DAQ Assistant, but I think the fastest way to get this fixed is to uninstall and reinstall NI software.  You can find instructions for doing this in this forum.  It sounds like something got corrupted in either LabVIEW, DAQmx or another piece of software and these issues are difficult to track down.
Jim Schwartz
Message 12 of 13
(1,199 Views)
So after following the attached instructions to remove all of Labview and reinstall it , it finally works again. I followed the steps for removing the software with the msiblast utility and editing the registry. I then installed only the development studio not the drivers. After I rebooted I went and installed the newest drivers and now everything is working as advertised. Thanks to everyone for helping me out, this was a frustrating one for sure.
Message 13 of 13
(1,171 Views)
