04-11-2006 08:28 AM
Hi jwdz,
This will not work with LV7.1. If you try it you'll immediately get the following error message:
"The format string wired to this node contains a bad or unknown format specifier (%code). Right-click the node and use Edit Format String to delete the bad specifier."
JLV
04-11-2006 08:30 AM
04-11-2006 09:35 AM - edited 04-11-2006 09:35 AM
JeanPierre,
Yes, you can omit inputs in the format string. You do need to specify at least *one* input, however. Also, you can repeat inputs.
-D
Message Edited by Darren on 04-11-2006 09:39 AM
