Data Acquisition - Labview produces duplicate entries after continuously running for 3 days
I am controlling a pilot process plant using labview and the data acquisition seems to have duplicate entries after running the process and labview continuously for 3 days. I am recording data for every 30 seconds from multiple sensors and actuators. Could someone help me with the same.
Message 1 of 10
(1,746 Views)
No. Unless you show - or better post - your code.
Paolo
Message 2 of 10
(1,737 Views)
Hi, this is a sample of my code.
Message 3 of 10
(1,732 Views)
So you find duplicate entries in the %Y%m%d_%H%M%S_Versuch.txt file? Your code can be greatly improved, but apart from this, I don't see how duplicates could be generated there. Can you post an example output file?
Paolo
Message 4 of 10
(1,710 Views)
Hi aparna,
I don't think someone is willing to help you with code like that:
(navigation window, highlighted area denotes a FullHD screen)
Generic suggestions: Cleanup your code. Use (more) subVIs instead of duplicating stuff. Implement better data handling…
I wonder how your code will run "correctly" at all with (several!) loops running forever stacked inside other loops also set to run forever!
Message 5 of 10
(1,701 Views)
My suggestion is to replace the code where you save the data:
Instead of using individual numeric/Boolean , save them as arrays,
convert them into string and that's it. It may be very difficult to debug that part of the code, easy to make mistakes.
Message 6 of 10
(1,660 Views)
Hi Paolo,
Thanks a lot for your response. Row 6836 onwards, you can see that the values just duplicate, though the actual values are fluctuating.
Thanks in advance for any help!
Regards
Aparna
Message 7 of 10
(1,567 Views)
Thanks for your response.
This code has been developed by previous colleagues and I have to work with this.
Message 8 of 10
(1,566 Views)
Message 9 of 10
(1,565 Views)
Hi aparna,
When you "have to work with this" then you have to accept its bugs.
When you would improve the code you have the chance to eliminate those bugs…
It's your decision!
Simple solution: don't run the VI for more than 2 days 😉
(Btw. it 's not "LabVIEW" that "produces duplicates" it's still your VI which is buggy.)
Message 10 of 10
(1,548 Views)
