Data Question
For just a little more performance enhancement you could commit the task prior to entering the loop and avoid a few extra state transitions.  (Going by memory but I seem to recall there is a "Control Task" vi
Message 11 of 20
(1,998 Views)
is this how I get mutiple channels to read?  > Dev0/Ai1:Ai3
Message 12 of 20
(1,994 Views)
ok guys, with your help I've got the marked 3000 points...but it's coming out to be 3719 data points when 30 cycles are ran. Where are the 719 points that I don't need coming from?
Message 13 of 20
(1,971 Views)
I don't see anyplace where you are configuring the sample rate or number of samples so I don't understand how you can expect anything. The driver uses the same basic format as DAQmx so I would suggest you look at those examples if you don't have anything from the vendor.
Message 14 of 20
(1,963 Views)
I thought I was using the loop for my control...the delay time rather.
Message 15 of 20
(1,961 Views)
The windows clock is not going to be very accurate and is subject to a great deal of jitter. I have no idea what kind of card you are using but you should check the specs to see what sort of hardware timed sample rate it has and specifically set that. Then you should be able to set number of samples to read. Without specifying either of these, you are just going to keep getting random results.
Message 16 of 20
(1,946 Views)
Take another look at the example I posted.  I showed you how to configure the sample clock.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 17 of 20
(1,940 Views)
when I set up a sample clock, my "cycle counter" go nuts. It counts really fast and inconsistantly...is there any way to remedy this?
Message 18 of 20
(1,928 Views)
You need to show what your modification is.
Message 19 of 20
(1,917 Views)
ok, I've been busy with other things, so sorry for the late response. Here is my VI. I'm trying to take these samples based of a given frequency, say: 1Hz, 0.5 Hz. I want to take 100 reading a sec for 1HZ... so with 30 cycles I should have 3000 data points.
Message 20 of 20
(1,885 Views)
