Data loss during wireless serial data transmission from arduino to Labview
Hello to all. Smiley Happy
I constructed a voltage divider circuit to supply varying voltage to an arduino input pin. I used a labview program based on VISA to read serial data from the arduino, graph the serial data and write the aquired data to an lvm file (serial_arduino3). Initially when I use the arduino USB cable to read serial data, the results are alright (good_reading.jpg).
However when try to send the serial data wirelessly using a pair of APC220 tranceivers the data jumps from 0 to some value and back to 0 again (jumping.jpg). What could be the cause of this problem and how can I overcome it?
The code I have used on the arduino side is as follows:
int potPin = 0;    // select the input pin for the potentiometer
int val = 0;       // variable to store the value coming from the sensor
void setup()
  Serial.begin(9600);    // opens serial port, sets data rate to 9600 bps
void loop() {
  val = analogRead(potPin); // read the value from the voltage divider
  Serial.println(val);
  delay(1);
* The last delay determines the sampling rate. When I put a higher value for delay such as 500 I dont have this problem.
*The wireless data transmission properties are:
RF frequency: 434MHz
Baud rate: 9600
ADC of arduino: 10 bit
(4,667 Views)
Whether you are using wired or radio link should not affect the data.
What do you measure at the potPin with an oscilloscope or even a voltmeter while running both ways?  Your graphs show very different voltage magnitudes under the two conditions.
Is it possible that rf from the radio link is getting into the measurement circuit and changing the values?  Rectification of rf signals by low level circuits has been a problem since shortly after Marconi began transmitting data via radio waves.
Lynn
(4,656 Views)
thanks sir for ur reply.
I set the voltage divider output voltage to be different in both cases. I should have maintained the voltage in both cases to provide a clear comparison.
Initially I did also got inaccurate readings from the voltage divider output, however moving the wireless tranceiver antenna about 15cm away from the circuit solved this problem
These values alternating towards zero and coming up again only occur when I set the sampling s frequency on the arduino to 1milisecond. When the sampling frequency is set at 0.5 seconds, the voltage values do not 'fall' to zero and come up again.
I will try using an xbee tranceiver and observe the output.
(4,651 Views)
(4,651 Views)
I'm thinking you might be maxing out your baud rate. 9600 bits per second is not fast enough to acquire at 1KHz.
I'm assuming your read from the ADC is actually returning an I16 that is 10 bits data and 6 bits padded with zeros. So at 1 KHz you're producing 16,000 bits of data per second... too much for your baud rate. Depending on how your serial interface handles this... you could be overflowing a serial buffer with too much data... causing the data to fluctuate between valid data and invalid data.
Stephen B
(4,614 Views)
Hello ,
           I am trying to send command to arduino through labview wirelessly . It works in wired USB. But when i use RF communication (APC 220) http://wiki.openpilot.org/display/Doc/APC220+Transceiver+Telemetry   Through labview it does not works. Its working When i check RF (APC 220) directly in Arduino serial monitor. I am choosing correct COM port and baud rate is 9600. I am using arduino duemilanove board.
                                             Cable(USB)                     RF(APC220)
     Arduino serial monitor         works                              works
     Labview serial monitor         works                              not works???
my arduino program is
void setup() {
Serial.begin(9600); //initialize serial
pinMode(13, OUTPUT); //set pin 13 as output
void loop() {
while(Serial.available()){ //is there anything to read?
char getData = Serial.read(); //if yes, read it
if(getData == 'a'){
digitalWrite(13, HIGH);
Serial.print("LED On");
}else if(getData == 'b'){
digitalWrite(13, LOW);
Serial.print("LED Off");
I have attached my VI . If some one find solution please help me. Thanks in advance.
(4,254 Views)
