Data read using CAN (PCAN), XNET
There are many ways. You can also use the Call Library Node to directly call into the PCAN driver. No its not easy but aside from your time you spend on this it is free. Or you buy the earlier mentioned Driver. It costs something but is hassle free for you.
Rolf Kalbermatter  My Blog
Message 11 of 31
(3,758 Views)
ok thank you know where can see the tutorial or anything which helps me.
because I never work with it so,
Message 12 of 31
(3,754 Views)
How about using Ni CAN,
I installed this Ni CAN from ni website.
when i connect PCAN to my pc it will not detect in Ni MAX device and interface.
what should i do?
Message 13 of 31
(3,739 Views)
Hi Basavaraj,
It's the same answer as for NI-XNET: NI hardware drivers will only work for NI hardware!
(NI-CAN is the old-style CAN driver, usable only for old NI hardware CAN interfaces, and not supported anymore on modern LabVIEW versions.)
what should i do?
Use the driver supplied by Peak and leanr how to use it…
Message 14 of 31
(3,733 Views)
Without it we can't receive CAN data?
I want to just Read\Receive whatever coming from the CAN cable.
is there any other method?
Did you even *look* at what I provided? There is an "Rx Example.vi" in <..\PEAK CAN\Examples\> folder that sounds like a very good starting point. All you need to do is decode the CAN message into the values you want.
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
Message 15 of 31
(3,715 Views)
<LV Wrapper PCANBasic (LV2016).zip>
you are talking about this,
if yes then it is not containing any example folder.
Message 16 of 31
(3,707 Views)
Accepted by Basavaraj093
Opps. Sorry about that! 🤥
See attached PEAK CAN LV wrapper *with* examples this time. 🙃
Since there is no readme in the zip, here are some notes:
- put the PCANBasic.dll (x64 or x86) into the top folder so LV can find it. (download the PCAN basic SW package)
- Requires the PCAN drivers as well. (IE download and install the drivers)
- the "PCANBasic.h" is not required for LV but it helps greatly in understanding the parameters to pass.
Drivers:  https://www.peak-system.com/Drivers.523.0.html?&L=1
SW:   https://www.peak-system.com/Development.526.0.html?&L=1
Good luck
Message 17 of 31
(3,686 Views)
It would be nice if you save it to lower version.
I am using LabVIEW 2018.
Thanks in advance 😊
Message 18 of 31
(3,670 Views)
Thanks in advance 😊
Here you go
Message 19 of 31
(3,654 Views)
Thank you
Message 20 of 31
(3,624 Views)
