Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Data reduction - setting factor in program
alex_eagle
Member
11-03-2004
06:55 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there a possibility to set the data reduction factor of the data reduction Express VI in the program and not only in the settings of the Express VI itself ?
0
Kudos
Message
1
of 2
(2,846 Views)
Reply
Re: Data reduction - setting factor in program
Dennis_Knutson
Knight of NI
11-03-2004
08:22 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The only way at present to pass a value to an Express VI is to convert it to a normal VI and then add an input pin to the connector terminal.
0
Kudos
Message
2
of 2
(2,846 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
