Data reduction - setting factor in program
Is there a possibility to set the data reduction factor of the data reduction Express VI in the program and not only in the settings of the Express VI itself ?
(2,825 Views)
The only way at present to pass a value to an Express VI is to convert it to a normal VI and then add an input pin to the connector terminal.
(2,825 Views)
