Database Connectivity Toolkit (multi row insert)
Also - you can do this as a single insert - like this:
INSERT INTO table (value,name) VALUES (1.123,Temp1), (2.123,Temp2), (5.1235,Temp3);
(blog)
Message 21 of 31
(4,574 Views)
Hello aputman,
I've tried what you suggested but unfortunately it didn't work and I still get the same error.
As for what you suggested Sam, I can't do that because my values are generated by the DaqAssistant.
Message 22 of 31
(4,561 Views)
I never tried the syntax suggested by Sam, but certainly you can reproduce it modifying the code in your loop.
The string "INSERT INTO table (value,name) " should be injected into the shift register, then you should add your value pairs properly.
Paolo
Message 23 of 31
(4,551 Views)
You have misunderstood what I suggested, in your for loop, you generate N queries (one for each channel). Instead of that, generate a single query with N VALUE sections, like this:
 It has the exact same structure as your existing code but does the inserts in a single query.
(blog)
Message 24 of 31
(4,547 Views)
I'm sorry I didn't understand you at the beginnig, I tested that and I have the same string query as you showed me. But now I have an error that says that "Column count doesn't match value count at row 1". I'd like to inform you that my database table has two columns (value & channels).
Message 25 of 31
(4,539 Views)
Try your question in the database, e.g. SQL manager, and/or build the question there as a reference to how you need to formulate it in LV.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 26 of 31
(4,534 Views)
It seems like the decimal separator where the problem was, I added %.; to my query and now it works.
Thank you so much for your help, I really appreciate.
Message 27 of 31
(4,532 Views)
@AhciaDa wrote:
Hello aputman,
Well, of course it won't work if you don't incorporate all of the advice you have been given.  Smiley Frustrated
aputman
Message 28 of 31
(4,525 Views)
I did incorporate them and it works well now.
Thank you very much.
Message 29 of 31
(4,516 Views)
I try to insert multiple values in .mdb database using standard microsoft jet oledb connection.
My query is:
INSERT INTO T_Column (C_Name)
VALUES ('1') , ('2');
I use NI_Database_API.lvlib: DB Tools Execute Query.vi
I get the error -2147217900: "
L'erreur -2147217900 s'est produite à : NI_Database_API.lvlib:Conn Execute.vi->Add_Multiple_Columns_onDatabase.vi->Test_Create_big_database_optim.vi
Raisons possibles :
ADO Error: 0x80040E14
Exception occured in Microsoft JET Database Engine: Point-virgule absent à la fin de l'instruction SQL. dans NI_Database_API.lvlib:Conn Execute.vi->Add_Multiple_Columns_onDatabase.vi->Test_Create_big_database_optim.vi"
It indicates that the semicolon character is missing in the query...
I think that I can not execute multiple query because the request below works:
VALUES ('1') ;
What do I have to do to correct this?
I really need help urgently! Thanks for your help!
Message 30 of 31
(4,254 Views)
